power swicth - which type of mosfet and driver to choose
marabout
Newbie level 2
Newbie level 2
swicth
hi all
I would to design a simple power swtich controller for a lamp of 30 v dcc supply at a switching frequency of 1 Mhz . but I don't know which type of mosfet to choose low side or high side and which driver to choose. I need some advise
thank
[/img]
power swicth
1MHZ ???
you want your lamp to be switching on every 1 microsecond??????
WHAT IS THE PURPOSE ?
Re: power swicth
yes the lamp should flash every 1 microsecond of course it's the maximum frequency. and that frequency could variate between 1mhz and 1khz
the purpose is to change the color of the emitted light .
power swicth
purpose is not clear.
will you be able to distinguish its on/off time with your persistence of vision.
you know at what frequency your normal house hold ac lamps swithches.. and are you able to make out its on/off conditions?
