Hey Guys any one tell me is this circuit is suitable for power supply with backup battery
if not give me the circuit for the same.
my aim is the battery has to produce power at the time of power fails.
if there is a power the battery has to charge.
It should function. However it may not be very good from efficiency and charging perspective. R2 would dissipate power while battery is charging. Battery would continue to see higher charge voltage.
Take a look at the article below. On page 9 and 10 charging is explained. Page 10 contains a schematic with a LM317. It is a correct and safe way to charge a lead
acid battery and more efficient. Even more efficient solutions exist but they may be more complicated and expensive.
