flyinspace
Full Member level 2
Hi everyone,
Who know the scale of power supply & substrate noise in mixed signal IC? Assume the power supply is 5V and the circuit is MCU. I plan to simulate the CMRR capability of differential circuit, hence add some noise sources is necessary, I think.
I have heard that power supply & substrate noise belongs low frequency noise. I want to know the range of low frequency noise, and is 10Hz~1MHz resonable? How about the amplitude of the noise, maybe 50mv?
If I know the frequency range & amplitude of power supply noise, then I can generate the noise signal by Matlab, which can be as a PWL noise source added to the circuit. Finally, running transient analysis can observe the CMRR capability.
Thanks & best regards,
flyinspace
flyinspace
