d123
Advanced Member level 5
- Joined
- Jun 7, 2015
- Messages
- 2,505
- Helped
- 494
- Reputation
- 992
- Reaction score
- 525
- Trophy points
- 1,393
- Location
- Spain
- Activity points
- 27,148
12V is at full = rated load.3. Puffffffffffffff..... What does 12V AC on the transformer and in the datasheet refer to then if the unloaded voltage is 20V AC?
looks like it is a 1 amp TO-220, around 65 Deg C per Watt.
- You've hit the nail on the head there, the problem is to repeat the old paraphasing of a car advert in the '80's by the Not The Nine O'Clock News team in a book: "Designed by engineers, built by robots, driven by idiots,"There must be something else going on here.
CC = constant current circuit. The DMM said the output from the 7805 into the op amp/NMOS/LED circuit was 42mA...
Well, well, well. You are feeding a const current circuit from a regulated voltage source?
May I ask why you use a constant current source and a constant voltage source.
Do you really that high precision for driving a LED?
Isn't a simple series resistor and the constant voltage sufficient?
Klaus
There is a big misunderstanding.
A const current source has a very high voltage compliance; it needs to adjust the voltage to keep the current constant. Theoretically, a const current supply has infinite potential and infinite impedance.
In real life, we use a sense resistor and attempt to keep the voltage constant across this sense resistor (the way LM317 is often used as a const curr source). If we use a low voltage const voltage source, the const current source has no leeway to operate.
..."In real life..." - Do you mean I'm in some virtual reality experience? Thank goodness, such a dismal life isn't real, after all, phew....
Isn't the purpose of the op amp with a reference voltage driving a transistor and a sense resistor as the feedback to maintain the voltage across the sense resistor constant, and therefore the current?
... with a manufactured power supply (as opposed to home-made) the 7805 had no problem with the 55mA output... I appreciate all the stuff I've learnt in answers to this thread, but the problem must be the power supply design and the 2VA transformer.
Also, isn't it better, if you don't know how to design that stage, to use a fixed voltage regulator to limit the voltage that may be sourced to provide the constant current in the event of some fault rather than let it hit the supply rail voltage, as infinity isn't available?
