AbsoluteCPP
My requirement are:
1. Volts: 4.2, Max current 2A, for SIM300, GPS-M90, some relays and other circuitry
2. Volts: 3.3, for SD Memory card, current consumption is minimum
Circuit will take power from Car battery (12V), I need another backup battery in case of main battery cutoff, circuit will automatically switch to backup battery if main battery cuts off..
I am thinking of using Li-Ion battery, but unable to select voltages and current rating for battery.
I have built other circuitry and it is working perfectly, I am providing the power to the circuit from Power Supply Unit (circuit is currently on my desk ).
Only power supply section is need to be designed, And i am not good with electronics, So i need help.
My requirement are given above, suggest me design.
Need an Efficient Power supply design with a backup battery for the tracker.
Thanks.
Thanks.
