resurgence2012
Junior Member level 2
I am trying to build a power supply for a cold cathode crookes tube. I am
told the tube needs between 10 and 15KV. Does anyone have any information about appropriate power supplies circuits that you can share? The simpler, the better.
I have been trying to use a flyback transformer. Using a simple single transistor driver, and 30 volts going into the primary, I am guessing that I have more than 20kv coming from the secondary.
The output from the secondary is high frequency, but I believe it is DC because the flyback is modern. But the tube only goes on for about a second and then goes out. After that I
have to switch everything off and wait about ten minutes before trying again. I think I have probably done something basically wrong but I can't figure out what it is.
Thanks in advance for any help.
Pete
Pete
