Power supply for Burglar alarm circuit?
cupoftea
Advanced Member level 6
We have a burglar alarm circuit which is basically a 2 core power cable which runs
from house to house in a stretch of 300 Houses in a remote Scottish Village.
We often get power cuts , so the 2 core cable is powered from a 24V to 30V battery which is in the end house only.
In each house we have a microcontroller (3V3 , 2mA rail) and a burglar detector (5V, 2mA rail).
This 3v3 and 5v comes off the 2 core cable (one in each house) as in the attached schem.
LTspice and .PNG schem as attached.
Because it often needs to run off battery,
the bias power drawn by the linear regulators needs to be as low as is possible. So the attached one draws only 60uA
of bias current. There is no other way of making such a low-bias-current linear regulator it seems?
Do you know of a better way?
Also the comms between each of the microcontrollers also needs to be over the 2 core power cable, as we cannot have
a separate comms wire. As such, there is a comms module which does FSK comms over the power cable and this gets picked up by each microcontroller
in each house.
Obviously , in each house, we can't have the big electrolytic caps directly connected to the 24-30V bus, since this would
ruin the power_cable comms signalling. So as you can see on the schem, the electrolytic caps are "downstream" of high impedance bias circuitry.
This allows the FSK signalling system to work well over the entire power cable between all houses.
Another point is inrush current. This must be minimal since otherwise the very long power cable would radiate much noise and
destroy the operation of the microcontrollers. So the inrush must be no more than if all the circuits in each house was
drawing its maximum operational current of some 4mA each. This is achieved by way of the attached circuit, where the electrolytic caps
are downstream of high impedance bias circuitry which stops any high inrush current from ever happening.
In every 5th house, the units have a LED flasher circuit, this draws power from the power cable and makes a LED flash brightly for 15ms every 750ms.
-But only if any one of the houses is getting burgled.
As such there is a switch mode LED driver in these circuits which gets enabled after the storeage electrolytic capacitor has been charged up
at a rate off 8mA.
The problem is that the attached circuit has very high resistances in it, and multiple BJTs. We are worried that we
will get oscillations going on in these BJT circuits? How may we avoid this?
Also there are resistance of 10MEGs and 1MEG in the circuit shown. Do you think that the leakage currents in the solder mask surrounding these resistors may actually mean that their "effective resistance" is actually potentially much less than 10MEGs and 1MEG?
Also, even though the simulator shows a no load bias current of only 60uA.....this is with the shown BJTs with their particular hfe values.....in the real circuit, the bias current could be widely varying especially if a batch of BJTs is bought for production that have very low or very high hfe values.....how can we mitigate this? .....these variant hfe batchs could also cause major deviation in the 3v3 and 5v output voltages...how can we mitigate this?
Also, how can we re-design to get even lower bias current?
  • Low bias current linear regulator_1.zip
Sounds like a real sh!tty system and the overarching goal is to preserve the sh!te?
What kind of mud hut has not its own electric supply yet has anything worth burgling? Why not make them feed power locally and let the wire just be party line comms without the power fuss?
The whole thing seems rather unusual i have to confess...but its what they want and there are orders for many more of these systems.....its a "customer is always right" thing...specially when they are paying decent money for it.....we just let them have it...but wonder if we are doing it the right-est way?
The cable has to deliver the power and the comms, we have no way of changing their mind on that.
Start considering lowest power OpAmp, like Iq max 540 nA -
But stability for Cload, slew rate/transient response, all complicating issues. And EMI pickup
due to so many HiZ nodes in circuits, the challenges significant.
For sure, home environment, woodstove smoke and ash, cooking vapors.....dust......
In general one begins to think of a resilient mesh network for fault conditions, and no cable, coupled
with a protocol that manages very low S/N data transmission. Like the radio amateur's are doing at
2200 meters. And processors that sleep in single digit uA or better.
Thanks yes but they are expensive and pose a risk for obselescence/nil stock issues, especially nil stock for the high volumes needed.
They also are an ESD risk compared to good old rugged BJT circuits.
Also 30vin is a bit close to out top vin of 30v.
Having said that i see your point, we could just use a TPS715 and run current to it via a 10V zener say....
TPS715
Do wonder about the ESD situation though.....discrete BJTs are well rugged.
It would be good if a lot of different SOT23-5 linear regs had the same footprint just in case one went obselete....we would always pick the ADJ versions as the fixed versions are well known for going obselete.
Write your reply...
LaTeX Commands Quick-Menu:
