Felipe Salomão
Junior Member level 3
Goal:
Use 3 position switch to change color of RGB led (4 pins), position 1, color: green, position 2, color blue, position 3, color: red, see diagram, i not tested it yet, only with relay i was able to try make diagram, not know if this will work. If anything is wrong, or would be more simple using another way, please reply with solution.
Obs:
Toggle switch middle pin is when toggle switch is "off", so i tried solve it using relay, i think that i will have problem that when its off, negative signal not go to relay, this way it cant power on blue color led..
See diagram bellow
Obs:
See diagram bellow
