In datasheet of a P-Channel Power MOSFET
Si2333DS I see the symbol of the following. Does anyone have idea why there is a
diode drawn inside?
Another question is how I
D is defined. This is an P-Channel enhancement MOSFET, and the majority carrier holes would flow from S to D with V
D<V
S and V
G<V
S. So if we
define source-to-drain as the positive current direction, I
D should also be
positive.
However, the datasheet page 1 lists
negative I
D values. So does it mean the positive current direction is D-to-S?
[h=3]Error[/h]I also found in the top-left figure of page 3, V
DS, V
GS and I
D are marked as positive. But for a P-Channel Power MOSFET to work, at least both V
DS, V
GS should be negative, with I
D still depends on the positive direction definition.
As a comparison, in the
datasheet of Fairchild BSS84, the axis are labeled as –V
DS, -I
D, and all V
GS’s are negative.
So if Fairchild BSS84 is correct, then Vishay Si2333DS datasheet must be wrong?
Matt
