Wesley90
Junior Member level 1
Hello,
I need to measure the power consumed by the FPGA for any design loaded onto it.
The PCB for this chip was custom designed by one of the students and i want to measure the power consumption of it.
It has separate supplies viz
1. Core voltage
2. Auxillary voltage
3. Internal logic voltage
which are plugged into the FPGA as small circuit boards (3cms*3cms).
Which is the best ( most accurate) current sensing IC that I can use for this purpose?
And also how do I connect this IC in serial with the CORE voltage supply.?
Thanks in advance
1. Core voltage
Thanks in advance
