zhangz64
Junior Member level 3
Hello, Everyone.
My name is zhen.
I am designing a board as a voltage regulator for a ultrasound imaging device, LM96550 Ultrasound Transmit Pulser- Texas Instruments
The desired function of this board is to receive a 110AC input from power source and regulate it in to 11 different DC voltages for 11 different input.
-5V
5V
1.8V
3.3V
-55V
50V
-10V
10V
50V
40V
-40V
Here is my way of doing it.
I first managed to use an ATX to convert the 110AC into 12V/5V dc, and I am planing to use LM5001 High Voltage Switch Mode Regulator (TI chip) to boost the 12V to 50V. Then i will use an linear regulator to drop the 50V voltage to 40V. (the same way to obtain the 10V from 12V and 1.8 V from 5V.
By now, I have got 6 desired voltages.
Except all the negative ones,
The challenging ones for me is the -55 and -40, I could not find any TI chip regulators to obtain a negative voltage as low as -55/-40.
In the mean while, i accidentally found this AN-H59DB1 demo-board which is to convert a 12VDC input to 6 different voltages. Even though those 6 voltages are close to the desired voltages and even includes a negative voltages as low as -75, but those voltages do not match perfectly to the desired voltages.
Otherwise, i will just order it to save the trouble
I do not want/could to use any external circuit other than IC chips to do the job.
Is there a anyway to obtain the -55 or -40 VDC?(I was suggested to use transistor to build a regulator my self, but I have trouble doing it since i am a first year EE student)
Thank you for reading this and sorry for the wall of texts.
Any advises would be really appreciated.
Zhen
My name is zhen.
-5V
5V
1.8V
3.3V
-55V
50V
-10V
10V
50V
40V
-40V
Zhen
