power Inverter for CDI
rx5
Full Member level 2
Full Member level 2
cdi inverter
hello all...
need info on how much current/voltage is supplied by a typical magneto/source coil......... by a 110cc 4 stroke engine...
i tried to make a power inverter (12V-300VDC) but no success..... its a push-pull topology using SG3525 and IRF44 as switching... pri winding is 4T+4T #20 AWG magnet wire/ secondary is 58T #20..... its output is around 150VDC... but it STILL cant supply????? to the CDI circuit???? pls help.....
any suggestions??
cdi schematic
Could you tell me :
1. Kind of transformer u r using
2. PWM frequency
It's more help for me to help you if you provide me the schematic..
schematic cdi
rx5 said:
hello all...
any suggestions??
where did you get the circuit?
is it from sportdevices.com
i tried their dc-dc converter and it works for me, just make sure you got the right elements and components.
schematic diagram dc cdi
same as leinathan,
with circuit from transmic i have a good result so with circuit from westhost..
I've already build a DC to DC power supply for my Honda motorcycle, output voltage is 160VDC and the current is 0.2 A
