JaMe
Junior Member level 1
I'd like to get supply +3.8v from serial port. It will be used to power MAX3237, a RS-232 transceiver. Pin 4 and 7 at serial port is connected with 2 diodes 1N4148, and mixed together. Then, cathode of the diode is used to supply LM317(TO-227 package).
The problem is, once I connect LM317, the voltage at cathode comes from 10V down to 3V. Anyone help ?
