Power factor correction design for 2KW
Bjtpower
Full Member level 5
Full Member level 5
Dear Friends
Can anyone let me know the best Application note on the "POWER FACTOR CORRECTION"
Input voltage range:90-265vac
Output voltage :360-380V Max
Want to calculate the inductance values as well selection of Magnetics which is easily available in india (Manufacturer would be EPCOS,Cosmo ferrites,Ferroxcube)
let me know good weblinks and articles
Regards
Marx
Hello Guys,
I was searching for the Study stuffs from Google.
Where i am getting confused for the 3 modes of PFC
A.CCM
B.DCM
C.CrCM
how they are classified..?? and when to use which modes..??
Detailed document on the same.
Confusing..??
Marx
Hello,
Please find here ccm pfc in free ltspice simulator....it takes long time to run though..maybe you leave it overnight.
Also i attach CrCM BOOST PFC , AKA BCM BOOST.
(LTSPICE sim)
  • PFC CCM BOOST _LT1248.txt
  • 150W Boost PFC BCM.TXT
crcm has higher peak current and needs bigger mains filter...but is easier.....
Hello Guys
I have taken the reference of the Infineon Application note
now i have calculated the Inductor Value and current.
I dont know how to select the core and on what parameters..??
Kindly help me with the EPCOS Cores as well any cores so i can select
Hoping for your Favorable reply
Marx
Reactions: treez
    T
