chu
Junior Member level 3
disspation
hi everybody,
please help me on some questions. thanks in up-front.
1) in some of the datasheets, i saw "low Vce(sat)", as what i understand is this is Vce of BJT connected to output pin. if normal BJT is used, the Vce(sat) should be 0.7V, the point it starts saturate (because Vbe is 0.7V), if Vce lower than this value, then collector current Ic will drop extensively which we don't want. am i correct on this ? please correct me.
are there any chips with Vce(sat) lower ? example 0.3V ?
2) for some of the 12v fan driver chip, Icc=20mA but Io=500mA, i though Io is coming from Icc (kirchoff current law) ? how this happen ? please explaint.
3) ba6809 datasheet calculation on chip power dissipation is :
total power P-total=Pcc + Po ; Pcc=Vcc*Icc ; Po=Vo(low)*Io
i though whole chip power dissipation should only be Pcc ?? why is ba6809 calculated this way ?
is the Vo(low) means Vce ?? please explaint why.
if Vo=Vce true, then Pcc should have include Po. why not correct ?
4) does power disspation in absolute max rating means the max power the packaging can take ?
it doesn't related to IC power dissipation but IC power cannot more than it. true ??
5) when we were to use a fan motor driver, what item on power dissipation should we take care ? how about the load (fan) ?
thank u very much.
_________________
rgds,
chu
hi everybody,
thank u very much.
_________________
rgds,
chu
