Power connectors PCB and cable mount
engr_joni_ee
Advanced Member level 3
I am looking for PCB and cable mount power connectors. I have found the following two from Molex. These both are PCB mount power connector.
Molex 76825-0008
Molex 172064-1008
I am looking the counter part which can be mounted on the wires. What crimp connectors are used inside these housings ?
--- Updated ---
I found the following three connectors for cables. I am not sure if they fit on the PCB mount connectors in the first post.
you post the datasheets, but you don´t read them?
So you need us to read them for you?
Crimp: my hint: open the pdf and do a PDF_search for "crimp"
Counter part: my hint: open the pdf and do a PDF_search for "mates". Alternatively you just could read through the headlines of the datasheet sections.
You are not sure whether they fit with Molex 76825-0008
And the datsheet says: "Mates with part(s)... 76825" (underlined, so they even act as a link. Press on it and you get to the according site)
How can they be more clear and more easy?
Klaus
I found the following two parts.
Molex 76825-0008: PCB Mount Female Power Connector, Wire-to-Board, 5.7 mm, 2 Rows, 8 Contacts, Through Hole Right Angle
Molex 171692-0108: Male Power Connector, Mega-Fit 171692, Receptacle, 8 Ways, 5.7 mm
They both are Compatible. One is PCB mount power connector to be soldered on the PCB. And the other is a compatible connector for cables.
The crimp terminals for the cable connector are 172063 and 76823. These crimp connectors are for cables and to be inserted in Molex 171692-0108.
Is there any crimp socket for Molex 76825-0008 ?
LaTeX Commands Quick-Menu:
