bootaali
Newbie level 1
hi
i made a circuit of power amp..volts are ok and balanced at the both sides but the problem about voice..voice is not ok ..voice is weak not in pressure while volts a same according to circuit diagram...i am so wondering about this fault ..because i really dont understand about this problem..if volt have difference in circuit then can trace the fault..but volts are proper INPUT PRE DRIVE STAGE BIASING even output transistors.All stages OK but the sound is weak...so any person have any idea?? any suggestion???what could be problem..any ground problem?? i know here is a little missing in the circuit ..but what is missing i don,t know ... so please please please help me .. this is not a first time with me .. before i already make another circuit ..but same problem in that circuit..volt same but sound result weak poor...i changed my transformer filter capacitors bridge rectifier each and every thing but the problem is still ..so please help me:-(
