[SOLVED] Pouring Polygon over internal planes in Altium
MouradR
Junior Member level 1
Hi There,
I am designing 4-Layer PCB on Altium and having hard time in pouring polygon. Simply I have two internal planes for Vcc and GND and I want to pour polygons on each of them with the right net. But when I try to choose the right Layer which the polygon will be poured on I can not find it. All I can find the Top, Bottom and Mechanical Layers but not the GND AND Vcc planes.
Is this because I choose planes instead of layers for the internal connections ?
Cheers,
Mourad
yup...bcoz of plane..u can do copper pour only above layers..and my doubt is why r u pouring polygon above internal layer(GND n PWR)???
As kick said, you dont have to pour polygons again in a plane. The plane is already filled with copper. You can see this while you generate the gerbers.
Hi Guys,
Thanks for the quick response,
I am relatively new to Altium and didn't know that there is no need to pour polygons on planes :)
Cheers,
Mourad
