homer2k1
Newbie level 5
post synthesis gate level simulation
Short version:
How to configure VCS to understand multiple clocks for a gate-level simulation after clock tree synthesis and routing?
Long version, with details:
Are there any special tricks/command-line options necessary for running a post-synthesis gate-level simulation in VCS? After synthesis (specifically, after CTS and routing), a simple shift register in my design exhibits a certain race condition.
Specifically, the single clock to the shift register is being split/buffered as multiple clock inputs, distributed to the 32 D flip-flops comprising the register. Although each clock can be traced back to the same root of the clock tree, I think the multiple clocks are being "triggered" or added to the VCS event queues in an unexpected order. As a result, one particular bit in the register shifts early/incorrectly.
Are there commands during clock tree synthesis that I can use to aid the VCS simulation later? Or alternatively, am I using the right flags in VCS? Relevant details:
- everything is written in Verilog
- design works fine pre-synthesis, and is fine right before CTS, but the generated netlist after CTS exhibits this behavior
- using Synopsys CAD flow: Design Compiler (Y-2006.06-SP6) and Astro (Z-2007.03-SP10), with a 90-nm TSMC process
- VCS (B-2008.12) with the following flags: -sverilog +v2k +lint=all -v <path>/tcbn90ghp.v -y <path>/src_ver +libext+.v+ -timescale=100ps/100ps +timopt=300ps
Thanks in advance for your help!
Short version:
