Post Synopsys Synthesis Simulation Using ModelSim
FNK
Member level 3
Member level 3
modelsim synopsys library
Any idea how to do this?
modelsim timing.lib
Verilog(netlist)+sdf
modelsim synopsys technology library
vsim -sdfmin xxx.sdf
vsim -sdfmax xxx.sdf
modelsim sdfmax
# For Modeltech Simulator.
#VHDL
vlib work (create working library)
vlib target (create technology library)
vcom tech.vhd -work target (compiling technology library)
vcom -explicit netlist.vhd (compiling synopsys vhdl output)
vcom -explicit test_benches.vhd (compiling your test benches)
vsim -t ps -sdfmin /UUT=netilst.sdf test_benches (vsim with time=ps timing min (sdfmin/sdftyp/sdfmax) backannotation file= netlist.sdf (file writed by synopsys with command write_sdf (I'm not sure)) test_benches=architecture name of your test benches)
#Verilog
vlog -explicit netlist.v
vlog -explicit test_fixture.v
vsim -t ps -sdfmin /UUT=netilst.sdf test_fixture
worst case simulation with modelsim
I got some good docs from Xilinx Site for this. Hope it will be helpful.
I have now done this type of simulation ... thanks.
modelsim sdfmax
Using Model Technology ModelSim with Xilinx Foundation Series Software
modelsim + synopsys library
This one is best. It explains how to compile Simprim libraries
Using ModelSim with Xilinx Alliance Software.
post synthesis is simulation
If you use Xilinx core,then core lib is also needed.
best case sdf modelsim
Is it no diffrences between VHDL and Verilog?
sdfmax
Who exactly know about the different between -sdfmin, -sdftyp & -sdfmax in ModelSim?
sdftyp modelsim
EDA_Master said:
Sorry for my stupid question? :D Who is tnx?
Hi tnx,
Do you know the different between sdfmin, sdftyp and sdfmax?
modelsim worst case time delays
elektrom said:
Hi tnx,
SDF will annotate delay to your design and delay can be described under three conditions, which are min:typ:max. Normally, min means best case, max for worst case while typ for the situation between min and max.
-sdfXXX is a switch to choose annotate which kind of delay.
How to calculate the delay depends on your library. I recommend you dig deeper in SDF format and certain kind of timing library such .lib or .tlf.
Please correct me if i miss anything.
Thx.
sdf modelsim vlog vsim
THX, :eek:
