Position of an Object in HFSS
haydar
Full Member level 1
hi
having moved an object several times, it is hard to trace the final position of it.
what is the most accurate way to get the final position of an object?
1) From the menu choose:
3D Modeler > Measure > Position
2)Instead of moving you can edit the CreateXXX object and change the values there - or even better use parameters.
Itai
    haydar
hi
you are right, changing parameters makes parts easier to trace. however, sometimes moving objects is much faster, because of this I use move instead of other.
thanks a lot...
