PORTb interruption (CCS compiler)
Van der Waals
Member level 2
Member level 2
int_rb ccs
Hello all,
My code which consists on lightening a LED connected to RA3 with a push-button connected to RB6 was compiled with success (0 error , 2 warnings of conditions always true and false) but did no function when I tried to simulate it with ISIS however it was a simple one (see below),
would anybody help me in correcting it or give me another correct code written with the same compiler ?
thanks in advance.
I use PCW 4.057 version of CCS.
#include "C:\Documents and Settings\test 1.h"
  #ZERO_RAM
#define RB6 PIN_B6
int1 flag6;
#int_RB
void RB_isr()
if (!RB6) flag6=1;
delay_ms(300);
void main()
   port_b_pullups(TRUE);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   ext_int_edge(H_TO_L);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_RB);
   enable_interrupts(GLOBAL);
   set_tris_b(0xff);
   set_tris_a(0x00);
 flag6=0;
while(1)
  if (flag6)
     output_high(pin_a3);
     flag6=0;
ccs portb
first you have not specified your device.
Are u using External Interrupt or RB Port Status Change interrupt.
portb ccs
hi Saeed_pk,
My PIC is a 16F876,
if you don't mind, what's the difference between them ?
now only one interruption comes from RB6 and is generated by a push-button, (just to test the code) but then I'll have to manage at least 3 other interruptions inputs in the other pins.
I read that with the CCS compiler there is two different ISR (Interrupt Service Routine) depending on PortB pins:
RB0:
#INT_EXT
void ext_isr()
RB4,RB5,RB6,RB7:
#int_RB
void RB_isr()
Reactions: Kazz78
    Kazz78
