FrustratedEngineer
Newbie level 6
I am using MCLRE pin RA3 as digital i/p. The MCU used is PIC16F15323.
This is the config settings...
There is switch connected to RA3 pin (a 10K pull up is connected too.) If I press the switch and keep the following code commented, the program works fine.
But, when I uncomment the code and press the switch, the MCU resets.
The wdt clr function is called and there are no unwanted infinite loops.
Please confirm, where lies the problem.
// CONFIG1
#pragma config FEXTOSC = OFF // External Oscillator mode selection bits->Oscillator not enabled
#pragma config RSTOSC = HFINT1 // Power-up default value for COSC bits->HFINTOSC (1MHz)
#pragma config CLKOUTEN = OFF // Clock Out Enable bit->CLKOUT function is disabled; i/o or oscillator function on OSC2
#pragma config CSWEN = ON // Clock Switch Enable bit->Writing to NOSC and NDIV is allowed
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable bit->FSCM timer enabled
// CONFIG2
#pragma config MCLRE = OFF // Master Clear Enable bit->MCLR pin is GPIO -> Dig I/P
#pragma config PWRTE = OFF // Power-up Timer Enable bit->PWRT disabled
#pragma config LPBOREN = OFF // Low-Power BOR enable bit->ULPBOR disabled
#pragma config BOREN = ON // Brown-out reset enable bits->Brown-out Reset Enabled, SBOREN bit is ignored
#pragma config BORV = LO // Brown-out Reset Voltage Selection->Brown-out Reset Voltage (VBOR) set to 1.9V on LF, and 2.45V on F Devices
#pragma config ZCD = OFF // Zero-cross detect disable->Zero-cross detect circuit is disabled at POR.
#pragma config PPS1WAY = ON // Peripheral Pin Select one-way control->The PPSLOCK bit can be cleared and set only once in software
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable bit->Stack Overflow or Underflow will cause a reset
// CONFIG3
#pragma config WDTCPS = WDTCPS_31 // WDT Period Select bits->Divider ratio 1:65536; software control of WDTPS
#pragma config WDTE = ON // WDT operating mode->WDT enabled regardless of sleep; SWDTEN ignored
#pragma config WDTCWS = WDTCWS_7 // WDT Window Select bits->window always open (100%); software control; keyed access not required
#pragma config WDTCCS = SC // WDT input clock selector->Software Control
// CONFIG4
#pragma config BBSIZE = BB512 // Boot Block Size Selection bits->512 words boot block size
#pragma config BBEN = OFF // Boot Block Enable bit->Boot Block disabled
#pragma config SAFEN = OFF // SAF Enable bit->SAF disabled
#pragma config WRTAPP = OFF // Application Block Write Protection bit->Application Block not write protected
#pragma config WRTB = OFF // Boot Block Write Protection bit->Boot Block not write protected
#pragma config WRTC = OFF // Configuration Register Write Protection bit->Configuration Register not write protected
#pragma config WRTSAF = OFF // Storage Area Flash Write Protection bit->SAF not write protected
#pragma config LVP = OFF // Low Voltage Programming Enable bit->Low Voltage programming enabled. MCLR/Vpp pin function is MCLR.
// CONFIG5
#pragma config CP = OFF // UserNVM Program memory code protection bit->UserNVM code protection disabled
if(PORTAbits.RA3 == 1)
u8KeyPressed = D_KEY_NO_KEY_PRESSED;
