Port is not connected when using top module
Boris.b
Newbie
Newbie level 2
Hey,
I am trying to instantiate two modules via top one. The modules are an SPI one, and one that should toggle LED when byte is received.
When i try to use only one of the modules it works just fine, but when i instantiate them to try and connect them the MOSI line is always unconnected.
here are the files.
spi_slave.sv
module SPI_slave(SysClk, SCK, MOSI, MISO, SSEL, LED, rx_buf, tx_buf, rx_valid );
input SysClk;
input reg SCK, SSEL, MOSI;
output MISO;
output LED;
input reg [7:0] tx_buf;    // byte to transmit
output reg [7:0] rx_buf;   // byte that is has been received
output reg rx_valid;       // byte received flag
// sync clocks to avoid cross domain metastability
// sync SCK to the FPGA clock using a 3-bits shift register
reg [2:0] SCKr;  always @(posedge SysClk) SCKr <= {SCKr[1:0], SCK};
wire SCK_risingedge = (SCKr[2:1]==2'b01);  // now we can detect SCK rising edges
wire SCK_fallingedge = (SCKr[2:1]==2'b10);  // and falling edges
// same thing for SSEL
reg [2:0] SSELr;  always @(posedge SysClk) SSELr <= {SSELr[1:0], SSEL};
wire SSEL_active = ~SSELr[1];  // SSEL is active low
wire SSEL_startmessage = (SSELr[2:1]==2'b10);  // message starts at falling edge
wire SSEL_endmessage = (SSELr[2:1]==2'b01);  // message stops at rising edge
// and for MOSI
reg [1:0] MOSIr;  always @(posedge SysClk) MOSIr <= {MOSIr[0], MOSI};
wire MOSI_Sync_Data = MOSIr[1];  // synchronous version of MOSI input
// we handle SPI in 8-bits format, so we need a 3 bits counter to count the bits as they come in
reg [2:0] bitcnt;
reg [7:0] byte_data_received;
begin
  if(~SSEL_active)
    bitcnt <= 3'b000;
  else
  if(SCK_risingedge)
  begin
    bitcnt <= bitcnt + 3'b001;
    // implement a shift-left register (since we receive the data MSB first)
    rx_buf <= {rx_buf[6:0], MOSI_Sync_Data};
  end
end
always @(posedge SysClk) rx_valid <= SSEL_active && SCK_risingedge && (bitcnt==3'b111);
// we use the LSB of the data received to control an LED
reg LED;
always @(posedge SysClk) if(rx_valid) LED <= ~LED;
reg [7:0] byte_data_sent;
reg [7:0] cnt; // keep count of the received messages
always @(posedge SysClk) if(SSEL_startmessage) cnt<=cnt+8'h1;  // count the messages
if(SSEL_active)
begin
    byte_data_sent <= cnt;  // load count into transfer buffer
  else
  if(SCK_fallingedge)
  begin
    if(bitcnt==3'b000)
      byte_data_sent <= cnt;  // after that, we send count value
    else
      byte_data_sent <= {byte_data_sent[6:0], 1'b0}; // shift register
  end
end
assign MISO = byte_data_sent[7];  // send MSB first
// we assume that there is only one slave on the SPI bus
// so we don't bother with a tri-state buffer for MISO
// otherwise we would need to tri-state MISO when SSEL is inactive
endmodule
led_blink.sv
// Slow blinking a LED
/* module */
module blinking (
    input DataReceivedFlag,
    input clk,
    output reg LedOutput
    always @(posedge clk) begin
        if(DataReceivedFlag) begin
        LedOutput <= ~LedOutput;
        end
    end
endmodule
top_module.sv
module top_spi (
    // genral signals
    input i_sysclock,
    output o_ledSignal,
    // spi signals
    input reg i_spi_clk, i_spi_cs_n, i_spi_mosi,
    output reg o_spi_miso
wire ow_dataReadySignal;
wire mosi_signal;
blinking blinking_Instance(.DataReceivedFlag(ow_dataReadySignal), .clk(i_sysclock), .LedOutput(o_ledSignal));
SPI_slave spi_slave_instance(
                            .SysClk(i_sysclock),
                            .SCK(i_spi_clk),
                            .SSEL(i_spi_cs_n),
                            .MOSI(i_spi_mosi),
                            .MISO(o_spi_miso),
                            .rx_valid(ow_dataReadySignal)
endmodule
output from the netlist analyzer:
From what i read online this should work, but it does not. Any help will be greatly appriciated.
Best Regards
The design works. But no output depends on i_spi_mosi, thus it's discarded in synthesis.
Looks different if you connect rx_buf:
Issue: MOSI line remains unconnected when instantiating SPI_slave and led_blink modules together.
Recommendation: Check top-level module for proper signal connections and clock domain synchronization. Debug systematically, focusing on signal names and unintended interactions.
LaTeX Commands Quick-Menu:
