Port connections in XPS
spman
Full Member level 1
I'm new to XPS.
I've designed and imported a module into an XPS project. My module has an input clock signal in addition to PLB clock. This clock should be connected to the output of clock generator I have added. But the problem is when I want to connect the clock port of my module, I can't find output of clock generator in system assembly view.
I think perhaps this is because of classification of signals. The clock port of my module hasn't any class in system assembly view! But the class of clock generator output is "CLK".
I tried to change the class of my clock port when I was importing the module with "Create or Import Peripheral" tool. But the class was not changed. Also I tried by adding SIGIS=CLK to the MPD file. But it didn't work too.
Please help me.
Thanks in advance
i guess you need to put the following lines in your code also :
[syntax=vhdl]
attribute SIGIS : string;
attribute SIGIS of my_clk : signal is "Clk";
[/syntax]
[syntax=vhdl]
[/syntax]
Yes! It works!
Is changing the PMD file illegal?
