port connection in Virtuoso layout
fanshuo
Full Member level 5
Full Member level 5
Netherlands
virtuoso layout
In my layout, I assign the port material to be "metal pn". in LVS, it reported that the ports are missing.
What can I do to correctly connect ports to my circuit?
Thanks!
ic port layout
possibilities are :
1) short for corresponding port wiht some other port ... I n these case only few port will be missing.. OR..
2)Incorrect Layer eg drawing layer instead of pn....
If you are working on UMC foundry you have to use _tt layer instead of pn layers for port defination...... In this case all the ports will be missing....
Added after 47 seconds:
or the name used might be different (typo).... in this case you ll get extra port in layout warnings....
virtuoso layout add pin
fanshuo said:
... port material to be "metal pn".
Usually a metal no. of the pin is expected. Check your layers table (LSW) for the correct syntax.
Reactions: ranaya
    ranaya
virtuoso lsw
I am working using UMC indeed.
I tried metal_tt, but the LVS still report missing port
virtuoso layout pins lvs
r u getting only pin errors...?? or some short or net mismatch is also there....??
r u getting any extra port on layout warnings...???
how r u adding the pin?? using CTRL + P or putting label??
port layout
I just try to layout a resistor to see how it works.
The resistor has four ports in schematic. It's not label, it's port.
I got two kinds of errors
1. no similar net
2 missing port. All the 4 ports I have are missing
how to put a pin on the layout virtuoso
i could only say some layer might be missing liking contat or via..... can you post error report ...??? maybe sum1 her could help......:0
    fanshuo
connect to virtuoso port
I did not find any special things in the error report
BTW, I tried put the port metal directly to the resistor contact or using a metal-1 to connect them.Neither is successful.
Added after 1 hours 50 minutes:
The problem is solved by setting the port metal to pn
and add text of the type tt
Reactions: ranaya
    ranaya
layout port
another possibility...... thx for your feedback.....:)
