Polyphase filter simulation
aibrahim
Junior Member level 2
Hello All,
I'm designing a polyphase filter (i have designed multi section to creat many notches ) such that i get it functional over certain band.
Can any one tell me how i can measure its frequency responce.
Advanced thanks,
aibrahim said:
Hello All,
Advanced thanks,
Since during ac analyses you can have more than one signal source, it is no problem to use two sources with a phase difference of 90 deg. simulating the I and Q channel, respectively. (Observe the performance difference using + or - 90 deg).
Thanks alot, but the problem not in input really in recognizing output
I do the following expression and i can see the output in a nice way
Out= sqrtabs(outI+sqrt(-1)Outq)
so i can see the output correctely. really the problem in measuring noise i have to define single node for output
for differential architecture we simply add vcvs and measure output, but what i can do for a polyphase filter with cascaded section.
Advanced thanks,
Good paper about polyphase filter
I think it nice one,
Refgards,
