Polarity of flyback windings?
eem2am
Banned
Hello,
Ive just been handed a flyback transformer with one primary and one bias, and two secondaries which are 5v and 16v......so its a 5v winding which is the lower part of the 16v winding also...(autotransformer winding)
i happen to know which pins are connected to which winding but not which way round...........without powering up, how can i quickest check which way round the dots are.?
i have no winding diagram.
Can you scetch up the transformer itself?
Is it important that primary and secondary side is not conductive to each other?
Reactions: eem2am
    eem2am
Hi, You can simply check this with a low power square wave generator. Set the freq. to something like 200Khz and connect it to one winding. You can now check the other windings with an oscilloscope.
Cheers
Reactions: eem2am
    eem2am
The above is the best way, I have the gear now but when I was broke I had to do stuff without it.
I have tried a battery and a compass for this, but thats a little rough.
A quick way is to measure the inductance of a winding, then connect another of the windings in series with it, if the inductance goes up then the 2 are in phase, you have the start of one connected to the end of the other, if the inductance reduces then you have them out of phase.
Its only a guide, but this has worked for me when I couldnt be bothered going to the car to get the gear.
Reactions: eem2am
    eem2am
