Poisson's equation in cylindrical coordinates
subharpe
Full Member level 4
Full Member level 4
Bangalore,India
poisson equation cylindrical coordinates
Hi all,
Can anyone help me with some reference or some technique to solve Poisson's eqiation in cylindrical coordinates?
Thanks
poisson equation
Are you looking for an analytical solution to the differential equations or do you want a numerical solution because you are modeling some sort of device?
-Tip
I need analytical solution. I want to apply the boundary conditions and solve the problem.
cylindrical poisson equation
This equation is very common in several areas of science and engineering. Here are two of them so you will have some key words to search for.
Electrostatics
The Poisson equation is very common in electromagnetics to solve static (not changing with time) problems. Essentially is computes the electric potential function given the distribution of charge.
Mechanical Engineering
The Poisson equation arises often in heat transfer problems and fluid dynamics. In turbulent flow problems, Poisson's equation is used to compute the pressure.
Hope this helps!
-tip
Thanks for your benevolent help. I found the ways to solve Poisson's equation in cylindrical co-ordinates with recourse of Green's function.
electric potential cylindrical coordinates
hi all
Subharpe,
Do you want to solve Poisson's equation in cylindrical coordinates by numerical or analytical methods?
poisson equation spherical coordinates
Analytical, as I mentioen in previous posts, too.
