pointer validation in C
kk2mkk
Member level 2
Member level 2
Hyderabad India
if u have given a pointer *ptr how to validate weather this ptr points to a type char,float, double,int etc
i have googeled a lot but i dint got the answer.
thanks
KK
typedef.. : ? TRUE:FALSE = ... statement will tell you as a logical echo
typedef ? can have logicaly many qualifiers to many statements ask of it
you hash a define #define you can # an typedefine or typedef
you can also ask a defined entity what it is by echo in logic as per the given logical string asked or defined as any entity setter....
only way i can say it
just to see stuff # hashed
is c... as a #
as a # is a definate
c will also use the same sub qualification statement to parse your logical questions
a hash # is a logical known argument upon case a bit like a logical algurithm in its simplest forms
simply a way to extend the logise of the registers avalible
or like adding layers to a cake
as the base will be the closest to the recipe needed
* just points to a position in memory
so
? typedef->name of entity : ? : TRUE : FALSE
in c building a lookuptable as a typedefined header include and a set of defined entitys you can then look up the entitys as your entrys defined the way in arrays
even 3d arrays can be different lenght this way...
you use a
#define DOUBLES[0] = DOUBLE;
#define DOUBLES[1] = DOUBLE;
#define DWORDS[0] = DWORD;
#define DWORDS[2] = DWORD;
ETC...
THEN...
adding after LIKE...
#typedef DOUBLES[4],DWORDS[3],LONGS[2];
you can also assign sudonames to your types
so in your app you can have an array of types names
with a pointer YOU define what area of memory you look at
the way to do this is to use the sizeof command to size
an area of memory at a pointers address
x= sizeof *ptr;
then compare x to a known size typedef ...
this is laborious ... in terms of code size
it depends where your programming application comes from
judging what variable is stored in memory is hard ...
unless you have a hook on its poker {setters defined size}
a setter is a #define.... as a definate size
so.... there is no way without hooking the exe in memory and instead of loking at the size of the variable
find what referances it and look at what its defined size in memory is then look up the size and give an output
this is also easy if its a known exe or dll you want to hook too {easy}
if its in the same c app you want to see what it is then concider the defined typedefined array method above as a base for your class as an inc header
You don't know to what *ptr points and want to know?. I don't understand your question.
You could define the ptr* something where something is a struct. A menber of the struct identifies the type. Then you can check it.
hey you can just assign a variable to that & then just compile/build the program. then compiler will tell you what was the pointer type & which type you have used it for... simple... isn't it.... :)
main()
int *ip,i;
float *fp,f;
char *cp,ch;
ip=&i; fp=&f; cp=&ch;
ip++;
fp++;
cp++;
if((int)ip-(int)&i == 2 )
printf("\n ip is integer ptr");
if((int)fp-(int)&f == 4)
printf("\n fp is float ptr");
if((int)cp - (int)&ch == 1)
printf("\ncp is char ptr");
