point can't connect(Altium designed 14)
gwdbsuccess
Junior Member level 2
It's my first time to lay out the PCB
I have a problem as shown below
the right point and the left point can't connect together
the left is a Header, 16-Pin
plz help me with this problem.m(_ _)m
This is because those pads are not the same net, when you want to connect two different net together altium DXP prevents because it is a "Rule Violation"
good solution is that you go back to schematic and connect these pad in schematic and update them to PCB, so everything will be correct and you have no rule violation
however if you want to disable this option in DXP you can go to "DXP > preferences > PCB Editor >interactive routing "
and set "routing conflict resolution " to "None" !
