piyushpandey
Member level 4
Hello guys
I have made following circuit simple one in which I want to make one transistor on when I provide the high pulse( NPN ) and make another transistor on when I provide low pulse ( PNP ).
The schematic is here:
what I have seen that when I am testing the PNP and NPN individually than I am getting the switching correctly form both transistors.
But when I have made connections as per in the schematic and have made the base of both NPN and PNP common so that when I put the high pulse the
NPN gets on and when I put the low pulse the PNP gets on .
But what I am getting the result on the breadboard is that when I made the base of two NPN and PNP common to receive the input, both the leds start glowing without any pulse on the high_low_pulse terminal , actually that terminal is nothing but a wire on my breadboard which I use to connect to VCC for the high pulse and to GND for the low pulse.
why I am getting this unusual behaviour .
Also I have checked the voltage levels at the pnp and npn which are as follows:
PNP :
Emitter == 5.08 V
Base == 4.41 V
Collector == less than 1 V
NPN :
Emitter == 0 V
Base == 0 V
Collector == 3.52 V
according to this the emitter-base junction of the PNP transistor is forward bias and the colector-base junction is reverse biased .
whereas in case of NPN the base-collector are reverse biased .
I want to know do I am getting correct voltage values on the transistor terminals.
Thanks
PNP :
Emitter == 5.08 V
Base == 4.41 V
NPN :
Emitter == 0 V
Base == 0 V
Collector == 3.52 V
Thanks
