pn junction diode leakage current
p11
Banned
Full Member level 3
does the leakage current flows in forward biased condition too ? if so then why ... because as the p region is connected to the +ve terminal of the battery so the electrons in the p region ( responsible for leakage current) should be swept away from the junction being attracted by the _ve terminal of the battery , then how does the leakage current flows in forward biased condition?
Could you reference what you are referring to? Reverse leakage current seems unlikely to flow in a forward-biased PN diode. A diode with poor reverse recovery will experience "shoot-through" if the voltage across its terminals is suddenly reversed.
