asia_sheikh
Newbie level 1
Hello,
I am trying to add a Discrete device (Vendor provided spice model ) to HSPICE. I have tried different type of devices to add to HSPICE but all the devices give same result. (Source voltage of PMOS follows the Drain voltage) and device is always turned on and leaking current. :shock:
I have tried >200 voltage and <20 voltage PMOS devices. But the result is same. So, by checking in the HSPICE model files thoroughtly i couldn't find any solution. Can anyone tell me if i am using the wrong syntax to just check the switching of PMOS of any parameters are missing in my code? :sad:
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 .include 'discretemodelabc.sp' .option post runlvl=5 .OPTION GMIN = 1.0e-21 .OPTION BRIEF .OPTION METHOD =GEAR .OPTION PIVTOL=1.0e-22 .OPTION GMINDC=1.0e-21 .OPTION POST .OPTION ACCURATE =1 .GLOBAL GND VDD X122 DRN GT VDD DMP10H400SK3 RDD DRN GND 100M VSUP VDD GND PWL (0 0 3u 0 10u 5V 20u 20 TD=0) VGT GT GND PWL (0 0 3u 0 10u 5V 10.001u 0V 20u 0 TD=0) VGND GND 0 0V VNMOS GN GND 2V .tran 100f 40u .plot i(X1) .end
