usama14
Member level 5
Hi all. I'm working on a load switch circuit that drives a capacitive load of 1000uF and a GAN transistor in parallel. The schematic of the circuit is attached. The input voltage is 50V and the Pmos being used is IRF5210. The simulations show promising results(also catering the inrush currrent issue), but on the hardware, when the GAN is biased to -2.9V and the pulse is applied to the NPN transistor, the circuit turns on but draws the maximum current from the supply. Hence, the PMOS gets burned. The inrush current is limited to 0.4A max and the full load current can go upto 7A.
Any suggestions will be welcomed. Thankyou
