PMC magnetic wall aproximation of a resonator logic
yefj
Advanced Member level 5
As we can see bellow ,they say that for TE01_delta if a wave hits the birder between dielectric constants then it will reflect back so why exactly is this property is PMC(as they say bellow) PMC is perfect electric conductor,what does it has to do with reflecting a wave ? I see PMC only as a boundry that allows magnetic field to pass threw it while electric field vanishes. TE is transverse electic so we have magnetic component witht the direction of propagation. I cant see why PMC has the property to reflect TE01 wave? Thanks.
Hi yefj,
There seems to be a number of problems here.
PMC stands for Perfect Magnetic Conductor.
Since the reflection coefficient is 1, no power passes through the boundary. This type of boundary will screen both electric and magnetic fields down to DC (think of it as an open circuit in a transmission line). Obviously this point is irrelevant for non-TEM modes, since other modes such as the TE01 do not propagate at low frequencies.
If any mode sees an effective PMC, it will be reflected. I think the point your source is trying to make is that the dielectric with a high permittivity appears as something close to a PMC from the perspective of a TE01 mode.
