rrk
Junior Member level 1
I am looking for a 18 way plug and socket assembly that could be disengaged easily. The nature of the application is that it has to be removed several times and like Molex connectors, it is not so easy to pull off , and usually requires a set of pliers the first few times.
Is there any such assembly that could be plugged into each other and a set of screws on either side can be used to hold on to each other like serial/ old printer cables connectors. But of course, each way should be rated for 3A.
Thanks!
Thanks!
