kathirudaya
Newbie level 1
hi sir,
i am using orcad 16.5. while i convert into pcb the following errors occured and it will not creat pcb. how to correct these errors. pls help me..
#1 ERROR(SPMHNI-191): Device/Symbol check error detected.
ERROR(SPMHNI-195): Symbol 'CAPELECTRO' for device 'C_3_CAPELECTRO_1N' is missing pin '1'.
ERROR(SPMHNI-195): Symbol 'CAPELECTRO' for device 'C_3_CAPELECTRO_1N' is missing pin '2'.
#2 ERROR(SPMHNI-191): Device/Symbol check error detected.
ERROR(SPMHNI-195): Symbol 'LED5MM' for device 'LED_6_LED5MM_LED' is missing pin '2'.
ERROR(SPMHNI-195): Symbol 'LED5MM' for device 'LED_6_LED5MM_LED' is missing pin '1'.
------ Library Paths ------
MODULEPATH = .
C:/Cadence/SPB_16.5/share/local/pcb/modules
PSMPATH = .
symbols
../symbols
C:/Cadence/SPB_16.5/share/local/pcb/symbols
C:/Cadence/SPB_16.5/share/pcb/pcb_lib/symbols
C:/Cadence/SPB_16.5/share/pcb/allegrolib/symbols
PADPATH = .
symbols
../symbols
C:/Cadence/SPB_16.5/share/local/pcb/padstacks
------ Summary Statistics ------
#3 Run stopped because errors were detected
netrev run on May 8 11:19:41 2014
DESIGN NAME : '555TIMER 10MS'
PACKAGING ON Apr 21 2011 10:02:30
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
INTERFACE_TYPE PHYSICAL
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
3 errors detected
No oversight detected
MODULEPATH = .
PSMPATH = .
symbols
../symbols
PADPATH = .
symbols
../symbols
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
3 errors detected
