garvind25
Full Member level 3
I am trying to characterize the transistors for gm/Id design methodology. I am using LTSPICE for it and have the following queries. I hope someone can answer them:
** Can I define a constant capacitance value in LTSPICE such as Cox = 8.5fF/u^2 such that after simulation, I can manipulate the graph to plot expressions like fT = gm/2*3.14*W*L*Cox? If I simply use the magnitude of Cox as 8.5f, though I get the graph, the unit of the Y-axis isn’t frequency (as it should be). The x-axis is Vgs (swept by a dc sweep command).
** As I know, after the simulation, I can manipulate the graph to plot expressions on the y-axis (such as for fT as in above query). Is it possible to plot graphs with expressions on both Y axis and X axis?. For eg. how to plot a graph of fT vs gm/Id (where the fT expression will be on y axis and gm/Id expression on x axis).
Thanks in advance,
Arvind Gupta
Thanks in advance,
Arvind Gupta
