plotting gamma source and load circles!!
abdoeng
Advanced Member level 2
load circles
hi after i design lna and calculate gamma load,at certian power gain and noise figure can i easy ploting gamma source by change gamma load grafically
regards
i use ADS2003
hi,that is a question,that if i make pointer on gamma load circles,i can see the gamma input value.
there are functions Map1C and Map2C to map source to the output or vice versa, you might be able to use them together with moving marker (pointer) in the data display but I think you must write some equations in data display window. The other way is to write the whole maping equations set (you can find those in the text books, e.g. the one by Gonzales) in the data display.
flyhigh
