plot white noise PSD in matlab?
fanshuo
Full Member level 5
Full Member level 5
Netherlands
noise psd
how to do that without using "psd" command?
Thanks!
psd white noise
calculate the power spectral density using mathematical expressions and then plot the array.
Simple
power spectral density matlab
there is a scaling factor after the fft to make it a unitary transform
what is that?
psd noise
you can see fft of x as
y=fft(x,512);
df=fs/512;
m=fftshift(abs(y));
m=m.^2;
m1=20*log10(m);
p=unwrap(angle(y));
f = -(fs/2)+df:df:(fs/2);
%f=(0:length(y)-1)*fs/length(y);
figure;
plot(f,m1);title('magnitude')
Re: psd noise
y=fft(x,512);
df=fs/512;
m=fftshift(abs(y));
m=m.^2;
m1=20*log10(m);
p=unwrap(angle(y));
figure;
f = -(fs/2):df:(fs/2)-df; would be better
