plot waveform in cadence monte carlo analysis
Debdut
Full Member level 3
Full Member level 3
Hello,
I am running cadence virtuoso 6.1.5 and trying to sort out the monte carlo analysis for process variation and mismatch.
I want to plot the gain vs frequency plot of a single-ended amplifier for 10 runs i.e. I want to see the 10 gain-curves in a graph window.
The only option in EVAL TYPE in OUTPUT SETUP of the analysis remains fixed at "point". Can it be changed to other options?
The expression that I am trying to plot is VF("/out"). There is 1V ac amplitude at input. Should I have to change the expression?
