edajason said:As zmliu mentioned, that way doesn't work. You can just get one point of gm. Or have you tried it in this way? 'Cause in the Analog Artist, the simulation window won't let you save gm in dc sweeping. Any other thoughts?
opamp741 said:better to do this way..
1. specify analysis as OP
2. go to output/setup in ADE and specify ur gm/Id exp using calculator
3. do parametric simulation with one or more variables
thats all
I am attaching the pic for reference..
edajason said:Good to see that people are still looking at gm/id stuff. A simple way is to plot in hspice. Originally I was trying to do it in Cadence while following Prof. Murmann's gm/id design methodology. You can setup the expression in the artist environment with calculator, and then plot it. The new model is also including a parameter called "gmoverid". But it's more convienent to char your device in Hspice. Check Stanford EE214 (prof. Murmann) Notes.
