plot function with matlab
Bou
Full Member level 3
Full Member level 3
Hello,
If we have a function like this
f(x,y)
ans we want to plot it with matlab with a condition that y>x else f(x,y) is indifined
how we can do it?
10x
Not clear whether x is the domain of the f function, or if you're considering another implicit variable, such as t for instance representing the time line, therefore I'm assuming the 2nd case.
You can use the y>x constraint to create another curve ( e.g: z ) which contains the same value of f. You will now plot z(x,y) instead of f(x,y), but setting the range of the plot function as the size of the z funcion, such as something like that ( not tested ) :
axis([ min(t) max(t) min(z) max(z)])
