Plot data on a graph receiving from UART
PA3040
Advanced Member level 3
Dear All
My Temperature sensor is sending data to PC through serial port ( UART )
So I need to plot the graph using this data
It would be much appreciated any one can give me a software to plot this receiving data from serial port
Thanks in advance
Just google on something like ' data input to Excel from serial port '
Reactions: PA3040
    PA3040
Hello,
What is your O.S.
WinXP or ?
have a look on this
Reactions: PA3040
    PA3040
Hello,
What is your O.S.
WinXP or ?
have a look on this
Dear paulfjujo,
Thanks for the reply
OS is Windows Xp
Hi Dear;
Can we able to do this using MATH LAB
Thanks in advance
hello,
Here is an open source application for charting data sent via RS-232 port in real time.
https://code.google.com/p/serialchart/
this works fine with coma separator
Do you know how to use semicolon delimiter instead of coma delimiter ?
because i saw somewhere to use
display_sep=,
but even i add in setup file
display_sep =;
or display_sep =%3B
or display_sep =59
only coma can be used as separator..
to test it, i use 2 com ports : COM1 and COM2 linked by a null modem cable
and 1 terminal Vbray for com1
dialogue is OK inside the data window of Serial Chart..
and on Port Com1 with this script, to send data to com2 (for Serial Chart)
program test1;
// rev 29 nov 2013
var i: integer;
var j: integer;
var k: integer;
begin
ShowMessage('Test Serial Chart using COM1'+chr(10)+chr(13)+ ' Send from IC UART1 19200,N,8,1 '+chr(10)+chr(13));
Delay(1400);
j:=0;
i:=0;
while (j<100) do
 begin
  while (i<10) do
   begin
   //  str:= chr(i+48);
    ComSendChr(i+48);
        ComSendChr(44);  // comma
      //  ComSendChr(59); // semi colon
        k:=j div 10 ;
        ComSendChr(k+48);
        k:=j mod 10;
         ComSendChr(k+48);
          ComSendChr(13);
     i:= i+1;
     if i>9 then i:=0;
    j:=j+1;
    if j>100 then j:=0;
    Delay(150);
   end;
  end;
end;
end.
and config.scc
[_setup_]
port=COM2
baudrate=19200
#in pixels
width=1000
height=400
background_color =white
display_sep =;
display_sep =%3B
display_sep =59
grid_h_origin = 399
grid_h_step = 10
grid_h_color = #AFA
grid_h_origin_color = black
grid_v_origin = 0
grid_v_step = 10
grid_v_color = #AFA
grid_v_origin_color =black
[_default_]
min=-1
max=100
[section1]
param1 = value
param2 = value
[Field1]
min=0
max=100
color=#F00
[Field2]
color=blue
min=0
max=100
