PLL programing in AVR (C-lang.)
somf0872
Member level 5
Member level 5
adf4106 avr
Hi everybody,
Is there any C-code (just for learning purpose or example codes) for AVR controllers in order to program PLL from analog devices (specifically ADF4106 or ADF4107)?
I want some idea about the programming structure of PLLs in C.
I mean how to set the counter, timer for Current steering, etc.... I have gone thru the datasheet of ADF4106. Although they expalined in detail which bit has to programmed in which way but I am confuse how to organize them in a c-code.
--X--
Hi
This type of PLL using SPI to program internal registers
First you have to learn how PLL work
Then calculate register value
Down load SPI code from ATMEL site
Program the register using the SPI port
All the best
Bobi
