PLL Mode check in dsPIC33
gary36
Full Member level 4
Full Member level 4
Hi
I am currently using dsPIC33EV256GM106 and trying to experiment with the performance with and without PLL. My XTAL is 8MHz. I was trying with primary clock as well as FRC mode to compare the performance. I used the reference code from this link https://ww1.microchip.com/downloads/en/DeviceDoc/70005131a.pdf ( example 7-1 and 7-2). To my surprise with PLL (in FRC mode), the timing performance is worst. I am trying to toggle a port based on delay. What is the problem?
Timing
without PLL --output toggles in 44us
with PLL based on the code below--output toggles at 290 us
But with primary clock timing is same with or without PLL as 44us.
Here is my code (MPLABX IDE V3.00) for FRC
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
#pragma config FNOC= FRC
#pragma config IESO= OFF
#pragma config POSCMD= NONE
#pragma config OSCIOFNC= OFF
#pragma config FCKSM= CSDCMD
 main()
PLLFBD=63;
CLKDIVbits.PLLPOST=0;
CLKDIVbits.PLLPRE=1;              //
__builtin_write_OSCCONH(0x01);
__builtin_write_OSCCONL(OSCCON | 0x01);
while (OSCCONbits.COSC!= 0b001);
while (OSCCONbits.LOCK!= 1);
while(1)
  PORTCbits.RC11=1;
 delay();
  PORTCbits.RC11=0;
 delay();
void delay()
  char x;
for(x=0;x<10;x++){}
