sushl
Junior Member level 2
Hello All i'm looking to implement a PLL with the following specification through rtl code.
Requirement:
Develop an RTL PLL (phase-locked loop) logic with holdover functionality to ensure continuous phase synchronization of the output signal (pll_out) to the reference signal (signal_1) even during temporary unavailability of signal_1.
Functional Specifications:
Requirement:
- Input Signals:
- signal_1: 8KHz Phase-synced Reference Clock
- signal_2: 8KHz Local Clock
- clk_ref: 25MHz Clock
- Output Signal:
- pll_out: Output of PLL locked to signal_1
- Normal Operation:
- When signal_1 is present, pll_out should be phase-locked to signal_1.
- Holdover Operation:
- When signal_1 becomes unavailable, the pll_out should enter holdover mode.
- In holdover mode, pll_out should maintain the last known phase of signal_1.
- pll_out should use signal_2 as the 8KHz reference clock to maintain phase synchronization.
- Recovery from Holdover:
- When signal_1 becomes available again, pll_out should smoothly transition out of holdover mode and regain phase synchronization with signal_1.
- Performance:
- The PLL should achieve rapid phase synchronization with the input signals.
- The PLL should maintain low phase and frequency jitter in both normal and holdover modes.
- Resource Utilization:
- The PLL should minimize resource utilization on the FPGA or ASIC.
- Robustness:
- The PLL should be tolerant to occasional glitches or noise on the input signals.
- Testability:
- The PLL should include design features for easy testing and verification.
Since PLL's inside my FPGA typically operate at MHz input range i cannot use inbuilt PLL primitives or ip. My device is a cycloneiv fpga.
