pll ics around 300Mhz
srivatsaaithal
Newbie level 1
Newbie level 1
which pll ic available in india
I want a pll ic which is available in INDIA(bangalore) and it should not be a smd.
tsa5511 pic atmel
If you are looking for a dip-switch type, motorola has quite a few.
I would recomend an I2C type which is easily controlled by an ATMEL or PIC mcu. A good choice is the TSA5511-2.
There are quite a few schematics along with software available all over the net.
It is stocked by most TV/VCR parts suppliers, and can be found in a lot of philips surplus tuners.
cheers
sda
www.freddospage.nl
Look at:
hxxp://www.freddospage.nl/
What about searching for the IC and asking one of your friends here in the silicon valley to send it to you.(in bulk)
