mhtplsh
Full Member level 3
mc145151 design
I am designing FM transmitter 88~108Mhz with PLL.
This will hv .5Mhz steps.
Using MC145151-2. & MC 12073P single modulus prescaler.
Datasheet of MC145151-2 attached herewith.
I got this old IC's from a friend.
Using 4 Mhz crystal at pin no. 26-27 then devide by 512 with reference address input. Hence the reference freq. will be 7.8125Khz.
Prescaler will be devide by 64-MC 12073P.
The supply voltage will be 5V DC fully stabilised.
Now i am stucked at designing low pass filter design. I am going to use opamp as on page 18 as 4.1C.
This is very important part of design. Hence guidance required in the matter.
This is my first PLL project.
what type of VCO will be better.
I am thinking of using varactor based vco.
